hwIProject GetNumberOfPages
Returns the number of pages in the project.
hwIProject_handle GetNumberOfPages
Tcl Query
The number of number of pages.
None.
View new features for version 2023.1.
The Python API documentation for HyperView and HyperGraph.
Adds a new layer to the project.
Adds a new page to the project's page list.
Copies a page.
Cuts a page.
Returns the active page index.
Returns the layer for the given ID.
Returns a list of the layers on this page.
Returns the number of layers in the project.
Returns the page for the given page name.
Returns the Templex object handle. This handle type is dependent upon the current client type.
Returns the window for the given ID.
Inserts a page.
Checks to see if the session has unsaved data.
Checks to see if the project is empty.
Moves a page.
Combines pages.
Pastes previously copied or cut pages.
Removes the given page from the project's collection.
Sets the given page as active.
ON THIS PAGE
Tcl Query
None.
ON THIS PAGE
