plt3DIBarChart GetColor
Returns the bar chart color index.
plt3DIBarChart_handle GetColor
Tcl Query
Options include x, y, z or return value using the RGB format (255 255 255).
Returns the color index.
None.
View new features for version 2023.1.
The Python API documentation for HyperView and HyperGraph.
Gets a named meta-data value previously associated with the chart.
Gets the symbol style of the bar chart.
Sets the bar chart color index.
Sets the symbol style of the bar chart.
Tcl Query
None.
