plt3DIBarChart GetSymbolStyle
Gets the symbol style of the bar chart.
plt3DIBarChart_handle GetSymbolStyle
Tcl Query
Returns the symbol style index of the bar chart.
None.
View new features for version 2023.1.
The Python API documentation for HyperView and HyperGraph.
Returns the bar chart color index.
Gets a named meta-data value previously associated with the chart.
Sets the bar chart color index.
Sets the symbol style of the bar chart.
ON THIS PAGE
Tcl Query
None.
ON THIS PAGE
