plt3DISurface GetMeshMode
Returns the surface’s mesh mode.
plt3DISurface_handle GetMeshMode
Tcl Query
Returns the mesh mode; edges, features, mesh lines, or none.
None.
View new features for version 2023.1.
The Python API documentation for HyperView and HyperGraph.
Gets a handle to a plt3DICursor interface for the surface.
Gets the color of the surface.
Gets the handle of a particular data source from the surface.
Gets whether a surface is displayed in the legend.
Gets whether surface is highlighted.
Gets the color of mesh lines superimposed on the surface.
Gets a named meta-data value previously associated with the surface.
Gets whether a curve’s X, Y, and Z vectors are parameterized by U and V vectors.
Returns the surface’s polygon mode.
Gets whether surface is visible.
Sets the color of the surface.
Sets whether a surface is displayed in the legend.
Sets whether the surface is highlighted.
Sets the color of mesh lines superimposed on the surface.
Sets the surface’s mesh mode.
Associates a named meta-data value with the surface.
Sets whether a surface’s X, Y, and Z vectors are parameterized by U and V vectors.
Sets the surface’s polygon mode.
Sets whether the surface is visible.
ON THIS PAGE
Tcl Query
None.
ON THIS PAGE
