plt3DISurface SetHighlighted
Sets whether the surface is highlighted.
plt3DISurface_handle SetHighlighted enabled
Tcl Modify
The appearance of a highlighted surface will change to indicate that it is active or has been picked through the GUI. To see this effect, alter the highlighted flag to cause a redraw of the client.
- enabled
            - True
- Highlighted
- False
- Not highlighted
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetSurfaceHandle mySurfaceName
mySurfaceName SetHighlighted true
myClientName DrawErrors
None.
