pltIBuildPlotsCtrl SelectYComponent
Sets the value(s) for the Y component.
pltIBuildPlotsCtrl_handle SelectYComponent values
Tcl Modify
- values
- The input for the values variable is a list. The list must consist of the components that you want to use within curly braces, { }. Each string representing a component must also be within “ “ if there are any spaces in the string. Example: {“LOWER TORSO” “SHOULDER BELT”}. If you do not want a Y component to be set, empty {} must be inputted.
hwi GetSessionHandle sess;
sess GetClientManagerHandle mgr plot;
mgr GetBuildPlotsCtrlHandle build;
build SelectYComponent {" Resultant Force (N)" "Elastic Force (N)"};Errors
Keywords
Tcl
Build Plots
Modify
