pltIBuildPlotsCtrl SetLegend
Sets whether the legend is on.
pltIBuildPlotsCtrl_handle SetLegend legend_on
Tcl Modify
- legend_on
            - true
- If you want the legend to be on (visible).
- false
- If you want the legend to be off (invisible).
hwi GetSessionHandle sess;
sess GetClientManagerHandle mgr plot;
mgr GetBuildPlotsCtrlHandle build;
build SetLegend false;
build GeneratePlot;Errors
Keywords
Tcl
Build Plots
Legend
Modify
