pltIEdit GetFromValue
Gets the minimum value of the edited range.
pltIEdit_handle GetFromValue
Tcl Query
The minimum value of the edited range.
None.
View new features for version 2023.1.
The Python API documentation for HyperView and HyperGraph.
Gets the replacement expression of the edit.
Gets the interpolation state of the edit.
Gets the name of the edit.
Gets the orientation of the edit.
Gets the maximum value of the edited range.
Gets the type of the edit.
ON THIS PAGE
Tcl Query
None.
ON THIS PAGE
