pltIEdit GetToValue
Gets the maximum value of the edited range.
pltIEdit_handle GetToValue
Tcl Query
Returns the maximum value of the edited range.
None.
View new features for version 2023.1.
The Python API documentation for HyperView and HyperGraph.
Gets the replacement expression of the edit.
Gets the minimum value of the edited range.
Gets the interpolation state of the edit.
Gets the name of the edit.
Gets the orientation of the edit.
Gets the type of the edit.
Tcl Query
None.
