pltIVector GetDataIncrement
Gets the increment of data vector referenced by the datasource (vector).
pltIVector_handle GetDataIncrement
Tcl Query
This command gets the index increment of the concerned vector.
#Precondition: A curve must be available on the plot client window.
hwi GetActiveClientHandle cl;	#Must be a plot client.
cl GetCurveHandle crv 1;		#Get the handle of the curve at index 1.
crv GetVectorHandle yvec y;	#Possible options are x or y or u or v.
yvec GetDataIncrement;Errors
An error code is returned on failure.
Keywords
Tcl
DataSource
Vector
Query
