pltIVector GetMetaData
Returns the metadata for the particular datasource (vector).
pltIVector_handle GetMetaData key
Tcl Query
This command returns the metadata for the particular datasource (vector) for a particular key.
- key
- The name of the metadata.
#Precondition : A curve must be available on the plot client window.
hwi GetActiveClientHandle cl;#Must be a plot client.
cl GetCurveHandle crv 1;#Get the handle of the curve at index 1.
crv GetVectorHandle yvec y;#Possible options are x or y or u or v
yvec  GetMetaData HWUnit #will return the unit of that datasource (vector).Errors
None.
Keywords
Tcl
MetaData
Data Attribute
Vector
Query
