poIMeasure AddEntity
Adds the given entity to the measure from the specified model and pool.
poIMeasure_handle AddEntity id_str
HyperView Tcl Modify
This command adds the given entity ID/s in the current measure group from the specified model and pool.
- id_str
- Can be one of the following formats:- Regular Nodes
- "node model_id [node_pool] n1"
- Param Nodes
- "node model_id [node_pool] n1 n2 %1"
- Param-Param Node
- "node model_id [node_pool] n1 n2 %1 n3 n4 %2 %3"
- Elements
- "element model_id [element_pool] element_id"
- Components
- "part model_id [part_pool] part_id"
- Systems
- "system model_id [system_pool] system_id"
Returns a non-zero value.
