poIMeasure CreateItem
Creates the measure item.
poIMeasure_handle CreateItem save_from_set save_to_set
HyperView Tcl Modify
This command will create the measure item.
- save_from_set (Optional)
- Boolean argument to save the "from" set.
- save_to_set (Optional)
- Boolean argument to save the "to" set.
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page page_id
page GetWindowHandle window win_id
window GetClientHandle post
post GetMeasureHandle mindist measure_id
mindist AddMinDistFromSet from_set_id_str
mindist AddMinDistToSet to_set_id_str
mindist CreateItem true trueErrors
Returns 0 if successful, otherwise an error code.
