poIQueryDistanceRule GetDistance
Gets the distance value from the advanced query.
rule_handle GetDistance
HyperView Tcl Query
This command is used to get the distance value from the advanced query.
hwi OpenStack
hwi GetActiveClientHandle client
set ruleID [client AddQueryRule mindist]
client GetQueryRuleHandle rule_handle $ruleID
rule_handle SetDistance "30"
hwi CloseStack
This command returns HW_InvalidHandle, if the core object associated with
        the advanced query handle does not exist anymore.
