poIQueryDistanceRule GetStartAt
Gets the distance rule starting point from the advanced query.
rule_handle GetStartAt
HyperView Tcl Query
This command gets the starting point of the distance rule from the advanced query.
hwi OpenStack
hwi GetActiveClientHandle client
set ruleID [client AddQueryRule mindist]
client GetQueryRuleHandle rule_handle $ruleID
rule_handle SetDistance "50"
rule_handle SetStartAt Min
hwi CloseStack
This command returns empty, if SetStartAt is set to
        invalid values.
