poIScaleCtrl GetInterpolationScaleMode
Gets the scale mode.
poIScaleCtrl_handle GetInterpolationScaleMode
HyperView Tcl Query
This command returns the scale mode (scale, model_units, or model_percent).
None.
View new features for version 2023.1.
The Python API documentation for HyperView and HyperGraph.
Copies deformation data to the clipboard.
Gets the name of the nodal vector result that is used for animation.
Gets a list of datatypes suitable for animation.
Gets an analysis system number.
Gets the scale for X, Y, and Z.
Sets a specified data type as a new source for animation.
Sets the scale mode.
Sets the analysis system.
Sets the scale for the XYZ axis.
HyperView Tcl Query
None.
