poIScaleCtrl GetResultSystem
Gets an analysis system number.
poIScaleCtrl_handle GetResultSystem
HyperView Tcl Query
This command returns the system ID.
None.
View new features for version 2023.1.
The Python API documentation for HyperView and HyperGraph.
Copies deformation data to the clipboard.
Gets the name of the nodal vector result that is used for animation.
Gets a list of datatypes suitable for animation.
Gets the scale mode.
Gets the scale for X, Y, and Z.
Sets a specified data type as a new source for animation.
Sets the scale mode.
Sets the analysis system.
Sets the scale for the XYZ axis.
ON THIS PAGE
HyperView Tcl Query
None.
ON THIS PAGE
