poISelectionSet GetIDVisibility
Retrieves the visibility setting for the entity IDs of the current selection set.
selectionSet_handle GetIDVisibility
HyperView Tcl Query
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle AddSelectionSet node
puts "Current selection sets: [model_handle GetSelectionSetList]\n"
model_handle GetSelectionSetHandle selection_set_handle 1
selection_set_handle SetLabel "OurNodeSelectionSet"
selection_set_handle Add all
puts "Current selection set ID: [selection_set_handle GetID]"
puts "   Label: [selection_set_handle GetLabel]"
puts "   Size:  [selection_set_handle GetSize] [selection_set_handle GetType]s"
puts "   Default color:      [selection_set_handle GetColor]"
puts "   Default visibility: [selection_set_handle GetVisibility]"
puts "   Default ID visibility: [selection_set_handle GetIDVisibility]"
puts "----------------------"
selection_set_handle SetVisibility true
selection_set_handle SetIDVisibility true
puts "   Current ID visibility: [selection_set_handle GetIDVisibility]"
hwi CloseStackErrors
This command should always return the current visibility for entity IDs. If the selection set handle is not retrievable, this command returns false.
