poISelectionSet GetType
Retrieves the current data type for the selection set.
selectionSet_handle GetType
HyperView Tcl Query
This command returns the current type of the selection set. Type can be node, element, part, system, or assembly. The type is determined when creating a new selection set using the command AddSelectionSet on Model, for instance. If the selection set is invalid, this command returns 0.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle AddSelectionSet node
puts "Current selection sets: [model_handle GetSelectionSetList]\n"
model_handle GetSelectionSetHandle selection_set_handle 1
selection_set_handle SetLabel "OurNodeSelectionSet"
selection_set_handle Add all
puts "Current selection set ID: [selection_set_handle GetID]"
puts "   Label: [selection_set_handle GetLabel]"
puts "   Type:  [selection_set_handle GetType] "
puts "   Size:  [selection_set_handle GetSize] [selection_set_handle GetType]s"
puts "   Default color:      [selection_set_handle GetColor]"
puts "   Default visibility: [selection_set_handle GetVisibility]"
puts "----------------------"
selection_set_handle SetVisibility true
puts "   Current visibility: [selection_set_handle GetVisibility]"
hwi CloseStackError
This command should always return a valid type as long as a valid selection set handle is used. If the selection set handle is not retrievable, this command returns 0.
