poISubcase GetDataComponentComplexFilter
Returns whether or not the data component can be used with various complex filters.
subcase_handle GetDataComponentComplexFilter datatype datacomp
HyperView Tcl Query
This command returns whether or not the data component can be used with various complex filters (true or false).
- datatype
- The data type for the components which are requested.
- datacomp
- The label of the data component for which the complex filter is requested.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handleErrors
None.
