poISubcase GetDataTypeBinding
Returns the binding type of the data type specified.
subcase_handle GetDataTypeBinding datatype
HyperView Tcl Query
This command returns the binding for the data type specified. The possible values are: null, node, element, node_on_element, part, or system.
- datatype
- The data type for the binding which is requested.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetSubcaseHandle subcase_handle 1
set ndt [subcase_handle GetDataTypeBinding];
hwi CloseStackErrors
None.
