poITextAttribute GetSize
Gets the font size.
poITextAttribute_handle GetSize
HyperView Tcl Query
This command retrieves the font size.
None.
View new features for version 2023.1.
The Python API documentation for HyperView and HyperGraph.
Gets the text color.
Gets the font family.
Gets the font name for the current font.
Gets the text height.
Gets the text horizontal alignment.
Gets the font size.
Gets the font slant.
Gets the font vertical alignment.
Gets the visibility state of the text.
Gets the font weight.
Sets the font color.
Sets the font family.
Sets the font by name.
Sets the text height in pixels.
Sets the font horizontal alignment.
Sets the font size.
Sets the font slant.
Sets the font vertical alignment.
Enables/disables the text display.
Sets the font weight.
Gets the font size.
ON THIS PAGE
Gets the font size.
HyperView Tcl Query
None.
ON THIS PAGE
