poITextAttribute SetVisibility
Enables/disables the text display.
poITextAttribute_handle SetVisibility enable
HyperView Tcl Modify
This command enables/disables the text display.
- enable
            - True
- The text is displayed.
- False
- The text is not displayed.
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetLegendHandle myLegendName 1
myLegendName GetHeaderAttributeHandle myAttrName
myAttrName SetVisibility falseErrors
Returns 0 if successful, otherwise an error code.
