vidIMovie GetFilename
Returns the filename of the movie.
vidIMovie_handle GetFilename
Tcl Query
Returns the name of the movie file.
None.
View new features for version 2023.1.
The Python API documentation for HyperView and HyperGraph.
Returns the number of frames in the movie.
Tcl Query
None.
