vidIMovie GetNumberOfFrames
Returns the number of frames in the movie.
vidIMovie_handle GetNumberOfFrames
Tcl Query
Returns an integer specifying the number of frames in the loaded movie file.
None.
View new features for version 2023.1.
The Python API documentation for HyperView and HyperGraph.
Returns the filename of the movie.
ON THIS PAGE
Tcl Query
None.
ON THIS PAGE
