Fix Elements
Explore the tools used to fix elements.
View new features for Altair HyperWorks 2023.1.
Use the Model tool to quickly run solver-related checks on all/selected entities in the model and apply auto-correction where defined.
Use the Model Checker to configure solver validity checks, modify and create new checks and corrections, and fix modeling issues in an automatic or manual way.
Check contacts, components, or groups for element penetrations and intersections using the Penetration Check tool.
Check the connectivity between two or more components.
Use the Mass tool to calculate the mass, center of gravity (COG), and moments of inertia (MOI) of the model.
Use the Edges tool to find free edges and "T" connections in a group of shell elements and create1D elements from them.
Use the Find tool to find free faces in a group of 3D elements and create shell elements from them.
Use the Equivalence tool to find, tour, and equivalence duplicate nodes.
ON THIS PAGE
ON THIS PAGE
