Transform Models
View new features for Altair HyperWorks 2023.1.
Symmetry visualization allows partially modeled geometry to be shown in full extent by reflection and/or duplication or in the case of axisymmetric models, by 3D geometry generation.
Use the Explode tool to explode a model or selected components for improved visualization.
A new workflow emphasizing the multicore profile for standard crash post processing use cases.
ON THIS PAGE
ON THIS PAGE
