Export a Line Definition File
To export the trimmed line definition file as a text file from the Tracing panel.
View new features for Altair HyperWorks 2023.1.
A new workflow emphasizing the multicore profile for standard crash post processing use cases.
Use the Tracing tool to trace system, component, and node entities during animation.
ON THIS PAGE
ON THIS PAGE
