Add a Note
Add a note to a point on a curve.
                From the Line Chart, Bar Chart, or Complex Chart ribbon, click the
                        Notes tool.
                    Figure 1.  -
                Hover over the curve to locate the coordinates to add the note to. Once the
                    point value is displayed, left-click to add the note to the curve.
                Add a note to the window by clicking anywhere in the plot window. The note is displayed as View Note in this instance.
                Select the note's border, right-click and select Edit to
                    display the Entity Editor. Use this to edit the note's
                    properties.
                    Figure 2. Entity Editor - NotesTip: You can also use the Plot Browser to edit the note. Click on the note from the plot window to display its attributes in the Plot Browser.Tip: See Notes for more information on editing the note attributes.
