Browsers provide a structured view of model data, which you can use to review, modify, create, and manage
the contents of a model. In addition to visualization, browsers offer features like search, filtering, and sorting,
which enhance your ability to navigate and interact with the model data.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Tools and workflows that are dedicated to rapidly creating new parts for specific use cases, or amending existing
parts. The current capabilities are focused on stiffening parts.
Use the Ejection Mitigation (EM) tool for the automatic target marking according to FMVSS-226 rules, automatic positioning
of the headform impactor, and the automatic export of ready-to-run solver decks for all of the selected impact locations.
Use the IP Impact tools to automatically calculate the instrument panel (IP) testing area according to the regulations
FMVSS201 and ECE-R21, position the headform impactor, and export ready-to-run solver decks for all the selected impact
locations.
The Pedestrian Impact tool automates the vehicle marking, impactors positioning and the export of solver decks with minimal
input, therefore reducing the full process lead time.
The Vehicle Safety Tools preference file contains templates to plot IIHS front intrusion and IIHS side structure intrusion
plots for Radioss and LS-DYNA files.
The Compare Time History diagnostic tool consists of two pages. On the first page, the input data files, such as plot,
result, and FE files, are selected. Page two contains the data needed to compare the reference files and comparison
files.
Allows you to transform vector results from a time history or animation result files according to a coordinate system
defined by three nodes from the same result file.
The MPDB tool offers a complete automated post processing solution of the MPDB Frontal Compatibility Assessment load case,
for Radioss and LS-DYNA output files. It also has the capability to do the MPDB compatibility assessment for physical test data (scanned data)
written out in STL format.
Use PhysicsAI to build fast predictive models from CAE data. PhysicsAI can be trained on data with any physics or
remeshing and without design variables.
Explore, organize and manage your personal data, collaborate in teams, and connect to other data sources, such as
corporate PLM systems to access CAD data or publish simulation data.
files.
From the first Compare Time History page, select all reference files and
comparison files.
Click Load.
Page 2 is displayed after the files are loaded into their respective
client windows.
Select the required Result Type.
Select the items in the Result Request list box.
Select the Result Component.
Right-click in the Result Request list box.
If you want to compare selected y-requests for At max Value or Every
Time Step, click accordingly.
Click Isolate to isolate selected requests from list box
in HyperGraph, HyperView
and HyperMesh, depending on the options highlighted
for graphics display.
Click Show in HyperMesh for
selected requests from the list box in HyperGraph,
HyperView and HyperMesh, entities can be seen depending on the buttons
clicked for graphics display.
Click Hide to hide selected requests from list box in
HyperGraph, HyperView and HyperMesh, depending on the buttons clicked
