HyperWorks
HyperWorks
2023.1
  1. Home
  2. Multibody Modeling
  3. Vehicle Modeling
  4. Full Vehicle Events and Altair Driver
  5. Altair Driver Mathematical Methods
  • What's New
  • Get Started
  • Tutorials
  • Tool Finder
  • Manage Files and Data
  • Sessions and Report Templates
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Meshing and Elements
  • Model Build and Assembly
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • Squeak and Rattle Director
  • PhysicsAI
  • Results Data
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Tabulate Results
  • Text Files
  • Publishing and Reporting
  • Collaboration Tools
Index
HyperWorks
HyperWorks
  • What's New
    View new features for Altair HyperWorks 2023.1.
  • Get Started
  • Tutorials
  • Tool Finder
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • PhysicsAI
  • Results Data
  • Plot Data
    • MotionView Overview
    • Model Browser
    • MotionView Ribbons
    • MotionView CAD Interfacing
    • Flexible Bodies
      MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multibody dynamics models.
    • Functional Mockup Unit (FMU)
      Add an FMU to the model or export a model as an FMU.
    • Vehicle Modeling
      • Build and Analyze Models
      • Vehicle Libraries
      • Components Library
      • Leaf Spring Modeling
      • Road Modeling
      • Tire Modeling
      • Soft Soil Modeling
      • Full Vehicle Events and Altair Driver
        • Full Vehicle Models with Altair Driver and Events
          This section describes how to add a full vehicle model with the Altair Driver and include the events. The events are simulation commands that enable the Altair Driver control to perform the vehicle maneuvers. A model with an event exports an Altair Driver File (.adf) and the MotionSolve (.xml) files to be simulated.
        • Event Types
          This section describes all of the full vehicle events currently supported with Altair Driver. It also describes all of the events and their parameters.
        • Driver Overview
          The Altair Driver is a set of MotionView models and libraries that allows MotionView users to control and script vehicle events.
        • Controllers Library
          Controllers form the core of the driver. The Controller Library has various basic controllers its arsenal to calculate different driver outputs.
        • Additional Altair Driver File Blocks
        • Altair Driver Mathematical Methods
          • Cars and Trucks
          • Leaning Two and Three Wheeler Vehicles
          • Gain Tuning for Leaning Two and Three Wheeler Vehicles
        • Troubleshooting Driver Modeling
        • MotionView Interface
          Driver can be loaded using the Model Wizard of MDLLIB when the Full Vehicle with Driver option is chosen. Driver has some special requirements to interface with the vehicle model. These requirements are resolved automatically if the vehicle model is built using the Full vehicle with advanced driver option in the Model Wizard in MDLLIB.
        • Altair Driver File
          Driver uses the Altair Driver File (ADF) to access all the event parameters in the Solver.
      • Road Tools
      • 1D Vehicle System Models
      • Update Model Tool
      • Aerodynamics
      • Track Builder
    • Tcl/Tk Reference Guide
      Reference material for the scripting interface which is a set of Tcl/Tk commands.
    • MDL Reference Guide
    • MotionSolve Reference Guide
    • Templex and Math Reference Guide
    • MotionView Python Reference Guide
  • Media Files
  • Tabulate Results
  • Text Files
HyperWorks
HyperWorks
2023.1
  1. Home
  2. ...
    • Vehicle Modeling
  3. Altair Driver Mathematical Methods
  • What's New
  • Get Started
  • Tutorials
  • Tool Finder
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • PhysicsAI
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
Index
ON THIS PAGE
    • Cars and Trucks
    ON THIS PAGE
