Browsers provide a structured view of model data, which you can use to review, modify, create, and manage
the contents of a model. In addition to visualization, browsers offer features like search, filtering, and sorting,
which enhance your ability to navigate and interact with the model data.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Tools and workflows that are dedicated to rapidly creating new parts for specific use cases, or amending existing
parts. The current capabilities are focused on stiffening parts.
Use PhysicsAI to build fast predictive models from CAE data. PhysicsAI can be trained on data with any physics or
remeshing and without design variables.
This section describes how to add a full vehicle model with the Altair Driver and include the events. The events are simulation
commands that enable the Altair Driver control to perform the vehicle maneuvers. A model with an event exports an Altair
Driver File (.adf) and the MotionSolve (.xml) files to be simulated.
This section describes all of the full vehicle events currently supported with Altair Driver. It also describes all of
the events and their parameters.
Driver can be loaded using the Model Wizard of MDLLIB when the Full Vehicle with Driver option is chosen. Driver has
some special requirements to interface with the vehicle model. These requirements are resolved automatically if the
vehicle model is built using the Full vehicle with advanced driver option in the Model Wizard in MDLLIB.
The TeimOrbit reader can parse various entities to get data from the ADF file. These entities include: attributes, blocks,
subblocks, tables, units and comments.
Explore, organize and manage your personal data, collaborate in teams, and connect to other data sources, such as
corporate PLM systems to access CAD data or publish simulation data.
the Full Vehicle with Driver option is chosen. Driver has some special requirements to
Wizard in MDLLIB.
Setting the preference file: Driver GUI requires the HW environment to be under
MBD-Vehicle Dynamics Tools.
Building a vehicle model using the Model Wizard. All the options of the Model
Wizard are explained in separate sub-heading.
From the Model menu, select Assembly
Wizard.
Figure 3.
The Assembly Wizard dialog is
displayed.
Build the vehicle model using the Full vehicle with advanced
driver option.
Figure 4.
The Driver Analysis System with icon is displayed in the Model Browser. Select the Altair Driver Analysis in
the browser tree to open up the driver graphical user interface in
the property panel. This can be used to edit the connections with
the vehicle model and to provide vehicle parameters.
When Altair Driver is present in the model, all the full vehicle
events are accessible to the model. They can be added by
right-clicking on model and choosing the Add
Events option.
Figure 5.
The following sections provide additional insights on the
MotionView interface for Altair Driver.
TeimOrbit Format
The TeimOrbit reader can parse various entities to get data from the ADF file. These entities include: attributes, blocks, subblocks, tables, units and comments.
