Access the CVT for Scooter Models
The MBD-Vehicle Dynamics Tools must be loaded as a preference file.
Follow the steps below to load this profile and access the CVT Powertrain model:
View new features for Altair HyperWorks 2023.1.
MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multibody dynamics models.
Add an FMU to the model or export a model as an FMU.
Reference material for the scripting interface which is a set of Tcl/Tk commands.
Figure 3.
Figure 4.
Figure 5.
Figure 6. © 2023 Altair Engineering, Inc. All Rights Reserved.
