From the Model Browser, select the system to which the
output is to be added.
Right-click on a system in the Model Browser and select from the context menu.
OR
Right-click on an output folder in the Model Browser and
select Add Output from the context menu.
OR
From the Analyze ribbon, Simple Run tool set, click the
Outputs icon.
The Add Output dialog is displayed.
Specify a label for the output.
Specify a variable name for the output.
By default, variables names of entities in MotionView follow a certain convention. For example, all
output entities have a variable name starting with “tmplt_”. This is the
recommended convention to follow when building models in MotionView since it has many advantages in model editing
and model manipulation.
Click OK to close the window or
Apply to continue creating entities.
Once an output entity has been added to the model, the panel for the
output will automatically be displayed in the panel area.
