Defining an Output Using an Entity Set
Using this method, the output can be measured for all entities of a certain type that are currently present in the model.
View new features for Altair HyperWorks 2023.1.
MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multibody dynamics models.
Add an FMU to the model or export a model as an FMU.
Create and edit outputs, add an analysis using the task wizard, check the model, and run the solver.
Use the Outputs tool to create a result output request to the solver, which writes out the requested data for plotting data.
The main types of outputs that can be defined using output requests are displacement, velocity, acceleration, and force. In addition to these, more complex outputs can be extracted using the Expressions and User-defined output types. The output request plays a very important role in post processing the results from a solver run. Output requests also pave the way for signal processing of data that is generated by a multibody simulation.
In this case, the output is generated with respect to a selected entity
An expression based output can be used to generate outputs based on solver run time functions. Solvers like MotionSolve and ADAMS provide several functions to track various outputs during the solution process.
Through this method, a displacement , velocity, or acceleration between two bodies can be measured relative to each other.
Define the output using the User-Defined tab which will allow you to specify the properties of the output using user subroutines.
Use the Check tool to search for any missing references in defined entities or errors in properties.
The Run Solver tool allows you to save and run the current model.
Use the Reports tool to view the report definitions of associated analysis tasks.
Reference material for the scripting interface which is a set of Tcl/Tk commands.
ON THIS PAGE
ON THIS PAGE
