Create and Test NLFE Helical Springs
A helical spring, or a coil spring, is a member that stores energy and subsequently releases it. A helical spring is used in various applications like: automobile suspensions, engine valves, measuring scales, box springs, etc. An NLFE helical spring system is a MotionView system definition that can be used to represent a spring as a non-linear finite element body.
- Body 1 attachment - The body to which the spring will be attached at one end.
- Body 2 attachment - The body to which the spring will be attached at the other end.
- Point 1 attachment - Spring center point at the Body 1 attachment end which will be used to interface the spring with Body 1 attachment.
- Point 2 attachment - Spring center point at the Body 2 attachment that will be used to interface the spring with Body 2 attachment.
- Select Show additional parameters to specify variable names and labels for the points that are to be created. You can also edit the element density per coil of the spring coils.
- To return to default settings, click Reset to Defaults.
Test a Helical Spring
A test rig can be used to exercise a helical spring and plot its characteristics.
A test rig for a helical spring is provided in the installation at <altair_install>/utility/mbd/nlfe.
