A stabar, also known as anti-roll bar, is a member that is used in automobile
suspensions to increase roll stiffness. This helps reduce the body roll of a vehicle during
cornering or when the vehicle traverses on road undulations.
From the Assembly ribbon, click the NLFE
Stabars icon.
The Add an NLFEStabar Subsystem dialog is
displayed.
Click the System collector and decide which system the
stabar needs to be created in.
Specify a variable name and label for the stabar.
By default, variable names of entities in MotionView follow a certain convention. For example, all NLFE stabar entities have a
variable name starting with nlfesb_. This is the recommended
convention to follow when building models in MotionView since it has many advantages in model editing
and model manipulation.
Double-click the MaterialProperty collector and select a
material to define the stabar, or accept Steel as the default.
Click the Body collector and select the vehicle body on
which the stabar is mounted from the modeling window, or
double-click the collector to display the Model Tree
(from which the desired body can be selected).
In the same manner, select the attaching points and bodies on either side for
the drop link.
Note: Select Point 1 and Point 2
if available in the model. If not, activate the Use global point
coordinates check box and enter in the coordinates where
points for the attachments are to be created.
Enter Outer and Inner diameter values for the stabar tube.
Click on the Profile Points tab to define the profile of
the stabar.
Manually enter values for the profile points in the table of coordinates or
import values with a .csv file.
Tip: To change the number of points in the table, enter a value in
the Total number of points text box.
Click the Marker collector and select a reference marker
in which the profile points are defined.
The default is the global frame.
Among the profile points defined, select two points as locations to attach the
stabar to the mount body (frame) using the check box in the column at the
right.
Click OK.
The stabar system that is created has the following architecture:
