FBD Import/Export
Once you have defined FBD sections in HyperView, you can invoke the Export dialog (shown below), where you can select which sections are to be exported.
- XML
- CSV
Once the section file has been created, it can be shared and re-used on models having the same topology or it can be modified to change the original section definition.
