Reset the Input Collector
View new features for Altair HyperWorks 2023.1.
Animation files are opened using the Load Model panel.
Use the Measure tool to measure various distances and angles between entities.
The Results Browser allows you to view the model structure while providing find, display, and editing control of entities.
Entities can be selected using input collectors or the quick window selection method.
Input collectors allow you to select entities in a model to which you can apply various tool functions.
The extended entity selection menu provides a number of entity selection options.
Locator strings can be used to identify node/element/parts within a model.
A new workflow emphasizing the multicore profile for standard crash post processing use cases.
ON THIS PAGE
ON THIS PAGE
