Create Section Cuts
 Figure 4.
                Figure 4. The display of the section cut frame can be changed at any time using standard Show/Hide operations. Note that this does not make the section cut inactive.
View new features for Altair HyperWorks 2023.1.
Use the Section Cut tool to cut planar or spherical sections through a model.
Use the Contour tool to create contour plots of a model and graphically visualize the analysis results.
Use the Iso tool to display single iso values (iso surfaced for solids or iso line for shells) dependent on results data.
Use the Vector tool to set options for a vector plot.
Use the Tensor tool to view tensor plots of stress and strain directions and magnitudes for various solvers from elemental values.
Refresh Results is a convenient way to quickly refresh a result plot (contour, vector, tensor, or iso) whenever the display changes.
The Edit Legend dialog allows you to change the legend properties.
You can edit the contour, vector, or tensor plot legend in the graphics area.
Results in some analysis types come as complex numbers.
A listing of results that are computed in HyperView.
Nodal averaging of elemental results at a node refers to the average of all the element corner results passing through that node.
The averaging options allow you to limit the averaging of results to only a group of elements that are considered to be bound by same feature angle or face.
HyperView allows for plotting (contour, iso, vector, or tensor) across multiple overlaid models.
The fatigue manager allows you to write stress and strain results from a finite element analysis to an external file that can be used to set up a fatigue analysis.
The fatigue configuration file is a user-defined external ASCII-file through which the data groups from results of static/modal/transient analysis of different solvers can be read.
A new workflow emphasizing the multicore profile for standard crash post processing use cases.
                 to create a new section cut in the dialog.
                                to create a new section cut in the dialog. .
.  Figure 1.
                        Figure 1.  of the left
                    side of the microdialog to update it to either a planar
                    or spherical section cut.
 of the left
. . For
                        spherical section cuts, the yellow manipulator can be used to adjust the
                        radius of the sphere.
. For
                        radius of the sphere. .
 Figure 4.
