Create, Edit, and Display Marker Plots
Use the Marker tool to visualize result data by adding text on entities by ID and value, allowing for easy reference of result values on selected entities.
- Plots are based on the current load case and step, which can be reviewed and updated from the status bar or the browser.
- Existing plots can also be displayed or cleared using the plot icons in the Results Browser.
- Editing the definition for a displayed plot will automatically update the graphics. For large models, editing the plot definition may be faster if the plot is not displayed.
- All values displayed are the same as the Contour plot.
