Import Result Files
Import analysis result files to create plots, query results, and so on.
Before you can import results, first open a model or import a solver deck.
Currently, supported solver related extensions are:
- OptiStruct (h3d, op2, hdf5, h5)
- Nastran (xdb, op2, hdf5, h5)
- Abaqus (odb)
- ANSYS (rst)
For all other solver profiles, the Post ribbon points to panels for Contour, Vector, Deformed, and Transient workflows, which rely on *.res file availability.
To import a results file, do one of the following:
- Go to .
- From the Post ribbon, Results tool group, click the
Import tool.Figure 1.
Then, select a file type:
- Solver Result Files (Common)
- Import native solver output files directly into HyperMesh to use the latest post-processing tools.
- Batch Import
- Load combination files (*.csv) can be used to import files/resources and their relevant subcase and simulation steps to generate result entities.
- HyperMesh Result Files
- HyperMesh result files (.res) can be imported for post-processing using panel functionality.
