Beam Failures
- Stringer Axial Stress
- Stringer compressive buckling
The Stinger Axial Stress is a simple method which calculates the Compressive/Tensile margin of safety as:
MS= [(Compressive Stress limit)*(section Area)/(Axial Force)] -1; (resp. Tensile Stress limit)
In the case of freebody sections, Axial Force is mapped to the freebody resultant Fx.
- σx : average axial stress as (Axial Force)/(Section’s area)
- Fcc=Fcy*(1−.272(L'/ρ)/π*√E/Fcy)
- Fcy : material compressive stress limit
L'=(structuralpropertyLength)/√K_constraint
- K_constraint = “constraint coefficient” on structural property. Def=0.0699
- ρ : beam section’s radius of gyration
- E: material young’s modulus
