plink (middle of the gap)
Creates a PLINK element. The PLINK is created at the center location between the two components and is offset from the connector location.
View new features for Altair HyperWorks 2023.1.
Use the Connector Browser to view and modify connectors in the current model.
Use the Control Manager to create and edit the various types of controls that will be used later when realizing connectors.
Use the tools in the Create tool set to create connectors, assign controls, and realize.
Create a dummy connector entity to add mass to a part, or create areas of mass to represent parts not present in the CAD or FE data.
Use the Quality controller to perform various checks on connectors and realized FE.
Use the FE Absorb tools to create connectors from existing mesh that meet specific types of realizations.
View details for different types of realizations.
A list of realization types that can be specified for point connectors.
This realization creates beam elements between the shells and/or solid elements, connecting them using a contact definition.
This realization creates bar (CBAR) elements between the shell and/or solid elements and then connects the two using RBE3 elements.
This realization creates CFAST elements between the connecting links.
This realization creates weld (cweld) elements to connect the connector links.
This realization creates hexa elements between shell and/or solid elements connecting them with a tie contact definition.
Use this realization to create hexa clusters between shell components.
This realization creates one hexa cluster per connector and realizes a node to node connection to the linked shell meshes by adjusting it (shell coating).
Use the RBE3 Load Transfer realization to create MPCs using RBE3 elements between the nodes of shell-shell, shell-solid, or solid-solid groups by using spot connectors.
This realization creates spring (CBUSH, CELAS1, CON3D2) elements between the shell and/or solid elements and then connects using Rigid elements (RBE2, RBE3, DCOUP) elements.
A list of realization types that can be specified for fastener connectors.
A list of realization types that can be specified for line connectors.
A list of realization types that can be specified for area connectors.
Organize elements into connector groups.
The FE configuration file (feconfig.cfg) is used to define custom welds such as ACM (Area Contact Method) and other special types.
Attachments are an entity to facilitate the ease of joining subsystems.
Use the Connector tools to further define connections between components.
Abstract information incoming from the CAD hierarchy to robustly create connectors.
