Line Connector Realization Types
A list of realization types that can be specified for line connectors.
View new features for Altair HyperWorks 2023.1.
Use the Connector Browser to view and modify connectors in the current model.
Use the Control Manager to create and edit the various types of controls that will be used later when realizing connectors.
Use the tools in the Create tool set to create connectors, assign controls, and realize.
Create a dummy connector entity to add mass to a part, or create areas of mass to represent parts not present in the CAD or FE data.
Use the Quality controller to perform various checks on connectors and realized FE.
Use the FE Absorb tools to create connectors from existing mesh that meet specific types of realizations.
View details for different types of realizations.
A list of realization types that can be specified for point connectors.
A list of realization types that can be specified for fastener connectors.
This realization creates beam elements between the shells and/or solid elements, connecting them using a contact definition.
This realization creates hexa elements between shell and/or solid elements in order to connect them using a contact definition.
This realization creates hexa elements between the links and connects the link elements with the hexas using singular or multiple rigids.
This realization creates perpendicular and parallel vectors to the surface along a line/nodelist.
This realization realizes t-welds, lap-welds, laser-welds, and butt-welds.
This realization serves and realizes t-welds, lap-welds, and butt-welds at the same time.
This realization creates N rows of spring (SPRING2N) elements between shells and/or solids, where N is a user defined value.
A list of realization types that can be specified for area connectors.
Organize elements into connector groups.
The FE configuration file (feconfig.cfg) is used to define custom welds such as ACM (Area Contact Method) and other special types.
Attachments are an entity to facilitate the ease of joining subsystems.
Use the Connector tools to further define connections between components.
Abstract information incoming from the CAD hierarchy to robustly create connectors.
ON THIS PAGE
ON THIS PAGE
