Create Bounding Solids
Use the Solids: Bounding tool to create solids from enclosed surface volumes.
View new features for Altair HyperWorks 2023.1.
Define meshing preferences.
Each element has an associated element configuration. An element configuration tells HyperMesh how to draw, store, and work with the element.
Solver cards supported for elements.
Use the Element Quality view to review element quality while simultaneously editing your model.
Explore the different types of 1D mesh you can create in HyperMesh.
Explore the different types of 2D mesh you can create in HyperMesh.
Explore the different types of 3D mesh you can create in HyperMesh.
Supported 3D elements.
Explore the tools used to create 3D mesh.
Solids are closed volume of surfaces that can take any shape. Solids are three-dimensional entities that can be used in automatic tetra and solid meshing.
Use the Solids: Sphere tool to create spheres with solid or bounding surfaces.
Use the Solids: Box tool to create boxes with solid or bounding surfaces.
Use the Solids: Cylinder tool to create cylinders with solid or bounding surfaces.
Explore the tools used to create solid mesh.
Explore the tools used to edit 3D mesh.
to define additional
options.
Review each found/selected bounding surface group by clicking
and
