Remove Logos
Use the Defeature: Logos tool to find and remove logos.
View new features for Altair HyperWorks 2023.1.
Define geometry preferences.
Explore the tools used to setup topology.
Explore the tools used to create topology.
Explore the tools used to edit topology.
Use the Split tools to create fixed points and split surfaces or solids using a variety of methods.
Use the Unsplit tool to remove split lines so that split surfaces return to their previous unsplit state.
Use the Quick Edit tool to split surfaces and washers, change the category (shared, free, and so on) of edges, create or delete surfaces and points, project points, and trim fillets.
Use the Stitch tool to stitch and unstitch adjacent or overlapping surfaces, and suppress or unsuppress edges.
Use the Fillets tool to create a constant radius on lines, surfaces, and edges.
Use the Align/Project tool to project entities to lines, surfaces, or planes then remap and offset projected nodes.
Simplify a mesh by combining many small elements into a smaller number of larger ones.
Use the Detach tool to detach elements and solids from the surrounding structure.
Use the Box Trim tool trim the model, or selected subset, to fit any defined box volumes.
Use the Defeature tool to automatically find, review, and defeature holes and other non-essential features.
Use the Defeature: Cuts/Edge Fillets tool to extend surface edges and remove cutouts, fillets, and rounds.
Use the Defeature: Small Features tool to find and remove/fix small solids and surfaces.
Use the Defeature: Fillets tool to find and remove both round (convex) and fillet (concave) surfaces.
Use the Defeature: Holes tool to remove solid holes in the model.
Use the Defeature: Batch tool to perform automatic cleanup operations on selected surfaces.
Use the Preserve Edges tool to ensure that specific component edges and feature lines do not accidentally get discarded during auto cleanup or batch meshing.
In this section you will learn about updating CAD metadata and parameters.
Fix gaps between stitched edges and vertices to make the actual geometry of the surfaces consistent with the model topology.
Find intersections and penetrations between geometric surfaces and solids.
Find symmetrical surfaces or compare selected surface sets for symmetry. You can reorganize found symmetric surfaces into separate components or delete one subset of a pair of symmetric surface sets.
Make changes to the configuration of existing elements.
Change existing element types.
Change a group of elements from second order elements to first order elements, or vice versa.
Perform a model-based CAD-CAD, CAD-FE or FE-FE comparison between two models, or two selections of entities, and find and report geometrical/shape differences.
The Use Parasolid option, found in multiple Topology tools, helps you in creating/editing geometries using a parasolid geometry modeling kernel.
ON THIS PAGE
ON THIS PAGE
