Browsers provide a structured view of model data, which you can use to review, modify, create, and manage
the contents of a model. In addition to visualization, browsers offer features like search, filtering, and sorting,
which enhance your ability to navigate and interact with the model data.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
These tools enable the creation of 1D elements from surface lines, organizing them into components. They also offset/orient
these elements based on the attached shell elements and calculating properties of these 1D elements from 3D solid
or shell FE element sections.
Tools and workflows that are dedicated to rapidly creating new parts for specific use cases, or amending existing
parts. The current capabilities are focused on stiffening parts.
Use PhysicsAI to build fast predictive models from CAE data. PhysicsAI can be trained on data with any physics or
remeshing and without design variables.
Explore, organize and manage your personal data, collaborate in teams, and connect to other data sources, such as
corporate PLM systems to access CAD data or publish simulation data.
Use the Review tool to plot area moments of inertia and stiffness.
This tool allows you to plot area moments of inertia as well as stiffness terms
(Elyy, Elzz, and GJ) either as a contour or a vector plot. In addition, a legend
provides extra quantities such as Elemental axis (X,Y,Z), the orientation vector
(V), Neutral axis position, Shear center position, and released degrees of freedom
at both ends.
From the 1D ribbon, Edit Beam tool group, click the
Review tool.
Select the elements to review.
Use the first drop-down on the guide bar to select what
to plot.
Use the second drop-down to select the plot type.
The selected element must have a beamsection entity assigned to its property
in order to extract data names to contour or vector plot. If a material is
assigned with young modulus or shear modulus available, stiffness terms are
calculated. Shear modulus is not recalculated from Poisson's ratio.
Contour and vector plots enable you to see stiffness drop along a path.
Vector plots capture all beamsections assigned to a PBEAM/PBEAML and can
plot every intermediate station.
In the image above, the neutral axis line shows discontinuities in neutral
axis position. This could be due to element formulation changes (CBAR vs.
CBEAM) or inconsistent offset values. The shear center line displays the
shear center position after offset. This is useful when you do not know the
actual section shape.
If the Review offset checkbox is enabled, you can
hover over an element to review its current offset values and whether it's
in a displacement system or elemental system.
Figure 3.
Tip: Use the legend in the top-left of the modeling window to control the display of the plot.
