Edit and Position Primitives
Edit and position nondesign parts or subsystems in your design space.
Before you can edit non-design parts or sub-systems, you must Set Up Design Space Libraries. Alternatively, you can import a part or sub-system.
View new features for Altair HyperWorks 2023.1.
Voxel meshing fills an enclosed volume with voxels (hexas) of a pre-defined size.
Promotes design exploration of early concepts and mature structures.
A Design Space library is an automotive focused library that can be used to rapidly create full vehicle architecture concept models.
Extract an envelope by sweeping a volume.
The voxel workflow is used to generate design spaces for topology optimization. RBE3s are used to connect the design space to the structure.
Design spaces can also be connected to structural elements using tie-based contacts.
The voxel mesher will automatically fill voids, however, for large openings in the include and/or exclude package space, it is expected that the model is prepared beforehand. It is therefore recommended that you use the Hole/Gap Fill tool to generate the correct design space.
