Create Local Design Spaces
Use the Local tool to create a design within a predetermined localized region of an existing model. The tool will automatically patch the open voids, create the voxel design space, and create a TIE contact between the local design space and the surrounding structure.
- It is necessary to prepare the model beforehand; preparation must include patching open holes or gaps that are larger than the desired voxel mesh size. Using a combination of hole/gap fill and shrink wrap will get the model to the point it is ready for local design space creation.
- It is important to turn off the part(s) that are not applicable for the local design space creation and/or deselect them when selecting the appropriate part(s) for design space creation. It is often easier to make the display selection ready before entering the workflow.
The local design space workflow is designed to facilitate rapid model generation for topology optimization. Typical applications may include the concept design exploration of structural inserts or baffles within an enclosed structure.
- A local design space is created within the selected area.
- A TIE contact is created between the design space and the structure.
- Design variable cards (DTPL) are setup for topology optimization.
